iroc overheating problem any suggestion might help don't be afraid to comment
Old May 26, 2009 | 04:57 PM
austin's Avatar
Default iroc overheating problem any suggestion might help don't be afraid to comment
1986 iroc is overheating and it has all new cooling components
Old May 26, 2009 | 05:10 PM
jjz28's Avatar
blown headgasket maybe?
Old May 26, 2009 | 05:17 PM
jjz28's Avatar
maybe the fans arent running. does it heat up while moving or sitting still? the air dam will make them overheat if someone has trimmed it or if it is messed up. advance auto sells a lot of junk thermostats.
Old May 26, 2009 | 05:40 PM
do u have the air damn on. if missing it will cause overheating on certain yr cars.
Old May 26, 2009 | 06:44 PM
austin's Avatar
its a newly rebuilt motor so i dont think it would be head gasket it overheats when it is setting still so it couldnt be the air dam and the fan turns on at the right temp i think
Old May 26, 2009 | 07:07 PM
the air damn also channels the air through the radiator while setting still.
Old May 26, 2009 | 08:17 PM
austin's Avatar
would it really make that much difference
Old May 26, 2009 | 08:57 PM
yes one guy built one out of stainless. worked at a fabricating shop and got the ok from his boss to do it at off time. cured the problem. wanted to see what yr it was so i looked for the post and cant find it. i keep thinking it was a 87 but not sure.
Old May 27, 2009 | 01:47 PM
austin's Avatar
i stole the air dam off of an 87 (mine is and 86) and they don't match
Old Jun 1, 2009 | 01:02 AM
batateam's Avatar
maybe the fans arent new york asian escort running. does it heat up while moving or sitting still? the air dam will make them new york asian escorts overheat if new york escort someone has trimmed it or if it is messed up. advance auto sells a lot of junk thermostats.the new york escorts air damn also channels the air through the radiator while setting still.
bryan0609
82-92 V8 Tech
32
May 7, 2012 06:57 PM
IROCK11s
May 16, 2010 11:52 AM
ssteve12121
Mar 22, 2006 11:10 PM
