installing new battery
Old 01-22-2007 | 12:25 AM
Saint_Ali's Avatar
Default installing new battery
i have a new car battery but have never installed one before, any help would be appreciated, also what do i need to do to maintain it properly ?
Old 01-22-2007 | 12:33 AM
shnormo's Avatar
Default RE: installing new battery
Um definately need an 8 mm wrench to get the two bolts off of the cables. Then you need to losen the bolt at the bottom of the battery to be able to take it out. I BELIEVE it is a 12 mm i'm not 100% sure but that needs to come out a little bit, so install in reverse order. Sometimes you need to take that bolt out all the way.
Old 01-22-2007 | 07:10 PM
Saint_Ali's Avatar
well the only problem i had is trying to take the bolt off that hold the battery in, i tried moving the power steering resevoir but that still didnt give me a lot of room, im going to see if i can find a longer extension
Old 01-22-2007 | 11:25 PM
shnormo's Avatar
Also go spend the extra $3 spray some anti-corrosion stuff on the terminals. Yeah you should be able to get it with just a long extention.
Old 01-24-2007 | 06:27 PM
Saint_Ali's Avatar
i got a 10" extension and it was no problem there, i had to clean the positive terminal because it wouldnt hold any power on the new battery, but everything is good to go
Old 01-24-2007 | 07:13 PM
blackz87's Avatar
Should of bought the battery at Auto parts store that installs them. Less problems with the tie downs. Just stand there and watch. My opinion.
libertyforall1776
02-24-2014 03:11 PM
mr.blue
11-29-2011 12:47 AM
Imperial RS Marty
01-26-2011 08:23 PM
jason7504
11-17-2009 05:27 PM
72ponyeater
01-16-2007 10:17 PM
