installing external horn button
I just wanted to know how I would go about installing an external horn in my 89 RS. My horn won't stop blowing so I disconnected the horn through the convienience center under the steering wheel. Now I want to install the external horn button. Which wire (color) do I cut and attach to the external horn button? and what else do I attach to the external horn button?
It's A Green Wire. The Horn Is Located In Front Of The Front Drivers Side Fender Well. You'll Have To Trace The Wire Or Just Run A New Wire From The Horn To Your Button Then Run A Hot Wire To The Button. BEEP BEEP. Sick
