I'm an idiot...
Old Jun 24, 2008 | 07:27 PM
MusicMan's Avatar
The Jazz Man
Default I'm an idiot...
So, when I went to install my headers, I didn't want to use the stock studs, no room for deepwells. So I went to ace hardware, and bought 12 grade 5 bolts, and matching washers. Came home, installed the headers, went inside to take a break, and looked in a little box that came with the pacesetters. Yeah, there were header bolts. Will I be ok with the silver grade 5's, or do I need to remove them and use the ones included with the headers? Yay for finding out bolts were included AFTER I got the headers on.
Old Jun 24, 2008 | 10:14 PM
73camaroSS's Avatar
Default RE: I'm an idiot...
hahaha music that sucks but trust me everybody has done that at least once. not surs if you need to use the ones it came with,just make sure you used lock washers other wise they will come lose all the freaking time and do not use paper gaskets.
Old Jun 24, 2008 | 10:45 PM
The bolts you used will be fine, grade 5 is more than strong enough. As long as you got them on ok, then might as well leave it at this point. "Header bolts" are special in that they have a smaller hex head for giving more wrench clearance around the tubes.
Old Jun 25, 2008 | 12:47 AM
MusicMan's Avatar
The Jazz Man
As is what I saw, would've been nice to have when installing. I'm on to my next issue, the transmission.
Old Jun 25, 2008 | 12:52 AM
MadMikeZ28's Avatar
[sm=wakeup.gif] [sm=itsok.gif]You could screw up a wet dream!
Old Jun 25, 2008 | 12:53 AM
MusicMan's Avatar
The Jazz Man
Cletus83
LS Series Tech
Aug 29, 2010 07:03 PM
66Fastback
Jul 14, 2008 08:39 AM
95slvrZ28
Feb 13, 2008 10:52 PM
Puck90a
Feb 11, 2008 11:02 AM
drJ22
Jul 17, 2007 09:48 AM
