I redlined my engine! plz help!
RE: I redlined my engine! plz help!
Unless you got the PCM tuned you shouldn't have been able to go over 6k if even due to the rev limiter. Usually bouncing it a few times won't damage it that bad, never know though. Definitely don't drive it until you get it checked out.
ORIGINAL: Camaro 69
One of the things that gets damaged from over-revvingis the valve train. I wouldn't be surprised if you either bent a push rod, bent a valve, or snapped a rocker arm.
i dont have an auto, but does the rev limiter kick in if the tires are spinning? i had a corolla way back, and on ice i could rev that thing way up, no shifting, no limiter, no nothing.
martynlutherking
05-25-2010 11:12 PM
