how much horse power will this make
Old Mar 21, 2007 | 10:06 PM
interex1982's Avatar
Default how much horse power will this make
350 engine bored 40 overwith 9.6 to1 cr trick flow heads 2.02 1.60 195 runner edelbrook perfrom rpm intake 750 holley msd 8.5 wires summit blueprinted hei dist .473 .486 zcam rollar rockers
Old Mar 21, 2007 | 11:45 PM
Z15CAM's Avatar
Default RE: how much horse power will this make
Just a Guess. In coomparisson the 70 350 LT1 with 10.5:1 compression put out 360 to 370 Hp with approx the same cam specs on Solid FT. Since you're approx one point down on compression but .040" up in cubes, I would imagine similiar Hp with a little more torque.
If you have it Dyno'd let us know ))
Old Mar 22, 2007 | 12:34 AM
badinfluenceRS's Avatar
1970 still used the gross hp ratings tho right?
so a dyno will be lower bc of the hp calc method + parasitic drivetrain loss
bryanfav123
Mar 10, 2007 02:11 AM
91 RS
Feb 14, 2007 01:50 PM
Jims94LT1
Jan 1, 2007 10:38 PM
camkid
LS Series Tech
Jun 20, 2006 07:37 PM
