Help on deciding rim and tire size
Hello!
I have a 69 Camaro that I'm restoring and upgrading. Right now it has the regular 15" rim with 235/15 tires.
I want someones help on giving me some light if it's possible to install the following combination on the car using American Racing chrome Rims and BF Goodrich Tires:
Rear
Rim Size: 17x9
Part Number : AR605M7961C
Offset : +45
BackSide : 6.77 *
Hub Size : 73.2
Tire: 275/40ZR17 (Rim Width Range 9” - 11”)
Front
Rim Size : 17x8
Part Number : AR605M7861C
Offset : 0
BackSide : 4.5 *
Hub Size : 73.2
Tire: 235/40ZR17 (Rim Width Range 8” - 9.5”)
Do you believe this combination will fit okay on the car or will I need to do some modification to the suspension???
Thank you!
Axel
Mexico
Rear
Rim Size: 17x9
Offset : +45
BackSide : 6.77 *
Hub Size : 73.2
Front
Rim Size : 17x8
Offset : 0
BackSide : 4.5 *
Hub Size : 73.2
Thank you!
Axel
Mexico
They look great although right now if you turn the steering wheel all the way to the left or right, the tire will graze a bit the inner fender. I believe that problem can be solved if an spacer is installed on the rim.
Most of the guys I know with 69s run 225 on 15 x 7 in the front and 235 on 15 x 8 in the back and have no rubbing problems. I have 235s all the way around and the front rub just like yours. I will probably go to the 225s with 15 x 7 in the front. I was on a forum about two weeks ago and there was a lot of talk about tire size for a 69. I will see if I can find it and get back with the web site for you.
Check out this web site and see if it helps, they list a lot of combinations that might work for you. http://www.chevyasylum.com/tech/backspace.html
