Getting Codes from a 95 Camaro...HELP
Old Sep 28, 2009 | 07:30 AM
CamaroGirl1010's Avatar
Default Getting Codes from a 95 Camaro...HELP
I have a 95 Camaro, 3.4 V6. Every once in a while the car will either stall and when I re-start it the idle is too high, or the SES light comes on with the car making downshift type sound when I take my foot off the gas. I ruled out vacuum leaks, o2 sensors, and idle control valve by simply replacing them all.
My next problem is.....getting the codes. I know my car has the ODB1/ODB2 issue, so I purchased a cable (from a site that mentioned the 95 Camaro code problem) that I could hook up to my laptop and sent with the cable was a CD that was supposed to have software that gathered the data. It was all crap because the only thing on the CD was links to sites where I could get software...yeah right. I had to either spend more money or the software was so confusing or just plain didn't work.
Does anyone have any ideas where I can get software to get codes, or have any suggestions on what I can do that isn't going to cost me a fortune? Either software that is simple (I don't need all the graphs and various diagnostic data that I have no idea what any of it means, lol....I just want codes), or an inexpensive code reader I can get specifically for the 95 Camaro.
I can't believe how frustrating it is just to get damn codes off this car.
Old Sep 28, 2009 | 08:27 AM
The PCM in your car is OBDI, bud the diagnostic port is configured as OBDII. There is liitle, if any, OBDI software to run off a PC. What you need is a OBDI scanner, not a plain code reader, and an adapter cable from the OBDI scanner to the OBDII port.
Old Sep 28, 2009 | 12:24 PM
Thanks. Do you know where I can get a scanner like that? Or should I just go to my nearest Chevy dealer? I already bought an adaptable part that the seller claimed would enable me to get the codes, and that didn't work. I am spending money and getting nothing in return and am sick of it. lol
Andy Morris
Mar 1, 2014 09:43 PM
Chaotic94
Jan 30, 2013 01:34 PM
garysextro90@gmail.com
Nov 6, 2012 01:40 PM
cdnturboz
Aug 6, 2011 10:33 AM
Lee Willis
Dec 4, 2005 08:24 AM
