Fuse blowing
Old 08-31-2008 | 04:49 PM
Tealcam's Avatar
Default Fuse blowing
I have a 94 V6.
All of the sudden the fuse for the Dome lights and CD player will blow.
It is very intermitant. Sometimes it will last a week or two, sometimes only a few minutes.
At first I thought that it only happened when the door was open.
But now I think that moving around in the drivers seat will cause it.
It happens even when the radio is off, so I thought it had something to do with the dome light switch. But since then, it has blown with the doors closed. Once when I was reaching into my back pocket to get my wallet and once when I was reaching across to roll down the passenger window. Is it possible that there is a wire running under the seat that could be shorting out?
Any help will be appreciated
Thanks
Dave
Old 09-01-2008 | 07:38 AM
blackz87's Avatar
Default RE: Fuse blowing
Not unless you have power seats.
Old 09-01-2008 | 10:42 AM
Tealcam's Avatar
I found it!
It was not in the seat but in the center console. It was the light that goes on when you open the console cover. Somehow the wires got twisted and it looks like the insulation may have been striped a little too far before they installed the connector. So they would touch when the console was tweaked a little bit. Thanks for you input!
Phirewire
12-06-2013 11:59 AM
izayuhgawd
11-21-2011 09:24 PM
jdobbs
05-10-2011 06:59 PM
JL15689
10-15-2009 10:37 PM
aode06
12-08-2007 11:22 PM
Quick Reply: Fuse blowing
