fuel injector cleaner
Old Nov 14, 2007 | 07:43 PM
Saint_Ali's Avatar
Default fuel injector cleaner
whats the best fuel injector cleaner ? or the best way to clean a clogged injector ?
Old Nov 14, 2007 | 08:21 PM
t9ojetpilot's Avatar
Default RE: fuel injector cleaner
[&:] the best injector cleaner is motorvac or other autoshop injector cleaner. i know this costs a few $$$ but is money well spent. the stuff in a bottle that you buy at the local auto parts place has a negligable effect on actually cleaning the injector. you could send them out for a rebuild if cleaning them proves to not rectify your problem and youve verified its an injector problem. these are the only two ways ive found to truly clean an injector kurt
Old Nov 14, 2007 | 08:39 PM
Saint_Ali's Avatar
so theres nothing in a bottle that i can pour that will work ?
Old Nov 14, 2007 | 09:31 PM
86Z350's Avatar
You can try Lucas oil fuel system treatment. Jiffy Lube/Grease Monkey shops that specialize in oil changes have a vaccuum fed fuel system cleaner. Works really well to get a bunch of carbon off the valves, pistons and injectors. You can see and smell it work its way out the tail pipe. Really narly stuff.
If you use the fuel tank treatment stuff, they want you to keep using it again and again, its just a waste.
Old Nov 14, 2007 | 09:33 PM
If it is totally clogged the stuff you pour in the tank won't work, and it will need professional cleaning.Otherwise put in 3 or 4 cans of Techron in a full tank of gas and it should clear the partially clogged injectors by the time the fuel is burned up.
Old Nov 15, 2007 | 12:05 AM
I just went through a bad injector issue with our cavalier, different car but same concept. I traced the problem to a bad injector, so I bought a new one at the parts store. Engine ran fine at high speed, but idled like crap. A mechanic I know said his experience with injectors is to use only GM replacements (if replacing only one). A little FYI: aftermarket ones aren't perfectly matched to OEM's and will run either a tad richer or leaner than the others. Thecomputer will try to compensate and it winds up messing everything up, which is just what happened. I thought for the hell of it then, I'll try soaking the old one in carb cleaner. So I sprayed alot of carb cleaner in a small container,let the injector soak for 5-10 minutes, swooshed it around a bit, then put it back in the rail. Engine ran great after that! Obviously it was just gummed up and was stuck, and the carb cleaner instantly did the trick.
Old Nov 15, 2007 | 12:58 AM
Saint_Ali's Avatar
is it possible for a injector(s) to be louder to compensate for more air going into/exiting the engine that the computer is unaware of ?
Old Nov 15, 2007 | 01:55 AM
02StanGT's Avatar
What do you mean by louder?
Old Nov 15, 2007 | 10:25 AM
Saint_Ali's Avatar
like i can hear one ticking louder than normal, but i dont think its clogged cause i havent lost performance and its not running rich at all
Old Nov 15, 2007 | 01:28 PM
An injector noisier than the rest is probably going bad or has already done so. The injector itself is not capable of compensating for anything, its operation is totally under the control of the PCM.
