Front wheels
Old Jan 28, 2008 | 12:07 AM
luvmysccamaro's Avatar
Default Front wheels
My problem now is something to do with some kind of bar. My steering wheel isn't positioned right. So when we were getting it fixed, the mechanic said the steering wheel only goes on one way so that's not the problem. He also checked the rack andpinion was fine. He said it is some other kind of bar that hasis bent. Also when we looked at the front wheels, one of the wheels had excessive ware on the inside which proves that so kind of bar IS bent. If you have any idea what it might be, please tell me and tell me what it is called and how it might have happened.
Old Jan 28, 2008 | 12:34 AM
95slvrZ28's Avatar
Default RE: Front wheels
There are so many suspension/steering parts that it could be. Struts, steering linkage etc etc, you should probably see if you can either get some pics of the suspension from under the car or talk to your mechanic to see if you can't get a more technical description of the issue. Are you sure the alignment isn't off? That will cause the car to pull and cause wear on the tires etc. Just a thought. See what you can do to get us some more details.
Old Jan 28, 2008 | 01:56 AM
MadMikeZ28's Avatar
There is not much there but the "bars" that come out of the rack and the tie rod ends on each of those. They can get bent when bumped. Or your lower control arm but they atre pretty sturdy. were you in an accident or did you curb it???
Old Jan 28, 2008 | 02:36 AM
Im getting the alignment checked in a few days. We haven't been in a crash and the Carfax said that there was no crashes. We did curb it yesterday but this has been a problem since the day we bought it.
Old Jan 31, 2008 | 12:53 AM
Yep, the alignment was off but something is twisted but it is still good.
c4maro
Jun 7, 2009 10:18 PM
kinglet9787
Jan 3, 2009 09:42 PM
doinbout150
Oct 8, 2007 09:32 PM
bowtieguy
Sep 15, 2007 04:35 PM
