Do Z28's require premium fuel?
Old May 2, 2007 | 09:45 PM
prospectiveowner's Avatar
Default Do Z28's require premium fuel?
Hello all......I am considering buying a 1996 Z28 and was wondering if they require premium fuel only or if they will happily feed on regular....thanks in advance for the info.......
Old May 2, 2007 | 10:01 PM
uncle bill's Avatar
Default RE: Do Z28's require premium fuel?
PREMIUM. If you don't want trouble that is. 10 1/2 - 1 compression requires the use of 93 octane.
Old May 2, 2007 | 10:49 PM
Thanks
Old May 2, 2007 | 11:11 PM
badinfluenceRS's Avatar
20 extra cents is worth it...your thinking about getting a maro right?
Old May 2, 2007 | 11:47 PM
95slvrZ28's Avatar
If you use anything below premium the computer will retard the timing and you'll loose power, you can run mid grade without damage to the motor, but c'mon, that means less power, and nobody likes that. Anything 91 and up you're good.
SandRacer
82-92 V8 Tech
Sep 25, 2009 11:50 AM
mycarsux88
Dec 17, 2008 10:08 PM
JaySan
Dec 7, 2007 11:28 AM
th3po1son
Nov 6, 2007 01:51 AM
