disk brakes locking up
Old 04-07-2007 | 01:10 AM
danlint's Avatar
Default disk brakes locking up
I converted front drum to stock disk brakes on 68 Camaro RS. Put in power brake booster and changed master cylinder and put proportioning valve. But when I engage the brakes they lock up. Any suggestions on troubleshooting will be greatly appreciated. Thanks guys!
Old 04-07-2007 | 01:51 AM
vampyrico's Avatar
Default RE: disk brakes locking up
are the brakes you put in used? if so see about checking the piston out, make sure its not sticking. also, make sure all the vacuum lines are secure on the brake booster.
Old 04-07-2007 | 02:30 AM
MadMikeZ28's Avatar
Does it lock up and stay locked? Or are you just not used to good braking in that car???
Is the rod inside the booster adjusted proper?
camarodude77
12-16-2015 06:52 PM
soxsdad
70-81 V8 Tech
08-02-2009 08:47 AM
dingo0722
10-31-2008 07:40 PM
michmar
82-92 V6 Tech
09-03-2007 04:10 AM
350rs
11-04-2006 12:29 AM
Quick Reply: disk brakes locking up
