Differential Howling
Old Aug 7, 2006 | 07:36 PM
hampino's Avatar
Default Differential Howling
My 97 Z28 is eating my differential.
I replaced the stock GM diff a couple years ago w/ 410s.
The stock diff was makin all sorts of howling noises when i turned.
Now my 410s are makin the same howling noise when i turn.
I don't want to replace the gears AGAIN.
Not sure why this is happening. I'm not doing brakestands all the time... no really! haha.
I have an aluminum AAM diff cover and some heavy duty oil in there and it still howls when the gears heat up.
WHAT AM I SUPPOSED TO DO?
do the gears need adjusting? any suggestions?
thanks.
j
Old Aug 7, 2006 | 08:23 PM
SickSickSick's Avatar
Default RE: Differential Howling
howling is slack between the pinion and ring gear. could possibly be worn out bearings causing the slack. whatever the reason it will only get worse. sick
Old Aug 7, 2006 | 10:46 PM
hampino's Avatar
any ideas on why it's going out again? i do not drive my car that hard anymore, although LA is pretty rough on cars.
maybe a thicker weight oil or anything?
Old Aug 8, 2006 | 04:01 AM
MadMikeZ28's Avatar
Sounds like you do a lot of burnouts
Old Aug 8, 2006 | 04:32 PM
hampino's Avatar
my car is traction challenged.
she's special.[&:]
Old Aug 8, 2006 | 06:59 PM
hampino's Avatar
what about the clutches?
this is turning into a mess.
Old Aug 8, 2006 | 10:49 PM
what about your clutches? if your popping the clutch that is the reason for the premature rearend wear. the 7.5 and 7.62 won't take alot of abuse without the tale tale signs of wear. (especially on posi carriers ) peg leggers put very little strain on the rearend. if you must roast them manup and break out the wallet. you can get used gears on ebay for a fraction of the cost of new. sick
Old Aug 14, 2006 | 03:52 PM
hampino's Avatar
Turns out it WAS the clutches in the posi.
It's an Eaton, so I had it rebuilt and now she's good to go.
Woohoo!
mlopezart
Feb 24, 2012 12:20 PM
msharp1085
Feb 26, 2009 10:35 PM
oakwood69
Jul 15, 2008 11:28 PM
kisk
Apr 21, 2008 04:10 PM
shnormo
Oct 17, 2006 02:52 PM
