decodeing rear-end in 84 camaro z/28
anyone know were to go to get rear end casting numbers?i've got a 84 z/28 and want to know what size rear-end it is along with the gear ratio and if it is a posi or a limited slip any help would be helpful the only casting number i can find is under the third member and it reads 22522676
RE: decodeing rear-end in 84 camaro z/28
[X(] you might try finding the build tag that has the rpo codes the right rpo code will tell you exactly what you have. this label is commonly in the glove compartment or on the spare tire cover but im not sure where its at on the 84 camaro any help guys?? can also use the code from the top of the axle tube if you wanna crawl around let us know kurt
GQ1 : AXLE, STD RATIO
GS1 : AXLE REAR, 2.73 RATIO
GS3 : AXLE REAR, 3.73 RATIO
GS4 : AXLE REAR, 3.70 RATIO
GS5 : AXLE REAR, 4.11 RATIO
GS6 : AXLE REAR, 4.56 RATIO
GT1 : AXLE REAR, 2.56 RATIO
GT2 : AXLE REAR, 2.29 RATIO
GT4 : AXLE REAR, 3.73 RATIO (DUP WITH 5 X 1)
GT5 : AXLE REAR, 4.10 RATIO (DUP WITH GT8)
GT7 : AXLE REAR, 3.33 RATIO
GT8 : AXLE REAR, 4.10 RATIO (DUP WITH GT5)
GTY : AXLE, WIDE TRACK
GU1 : AXLE REAR, 2.41 RATIO
GU2 : AXLE REAR, 2.73 RATIO
ORIGINAL: cueball67
Z28 came standard with LG4 and the manual had a 3:23 & optional 3:73 The Auto had a 3:08 & optional 3:23.
The L69 option had a 3:73 for both the manual & auto.
That is the only stock axle ratios that came stock with the Z28 in 1984.
