68 Camaro Rear end
Old Oct 17, 2010 | 09:36 PM
Blackscorpion68's Avatar
Default 68 Camaro Rear end
I'm looking to replace the rear end on my 68 to something newer but not completely outrageous in price. I was told a 4th gen rear end would fit with little modification does anyone know if this is true?
Old Oct 18, 2010 | 12:52 AM
What's the plan, to get rear disc brakes and a posi in one shot?
If by little modification you mean cutting and grinding off the 4th gen suspension and coil spring mounts, welding on leaf spring perches to mount it to the 68's leafs, narrow the axle tubes, and get the axles shortened and re-splined, so that you can use the same style/backspace wheels as you have now, then yes it's true. If you wanted to try using the rearend without narrowing it, then you would need to use wheels with the backspacing to fit the 4th gen (which is gonna look dumb on a 1st gen), but even then it's still going to be too wide. 1st gen rearend: 60" wide. 4th Gen: 64.72" wide. I guess I coulda given a simple no, but this was more fun!!
Old Oct 18, 2010 | 09:25 AM
Yeah the whole point was to get it all in one shot posi , disc. And maybe even gears. swapping from coils to springs is not a big deal, but I was worried about having to narrow it. I'm thinking it might still b a better alternative, unless you can suggest something else? Thanks for the info
Old Oct 18, 2010 | 11:12 AM
camaroboy68ss's Avatar
June 2010 ROTM
Ride of the Year 2010
whats in the car now a 10 or 12 bolt?
Old Oct 18, 2010 | 02:37 PM
burnt68's Avatar
December 2010 ROTM
to bad your in texas im pulling my 3:08 10 bolt posi for a 12 bolt i bought.
nothing wrong with the 10 bolt but im gonna be pushing 425-450 hp so i figured i would upgrade over the winter!!
Old Oct 18, 2010 | 03:24 PM
edog2's Avatar
May 2010 ROTM Winner
If your going to throw that away, I think I could find a home for it. I just need the gears and posi. I promise I'll let you ship it and everything, lol.
Old Oct 18, 2010 | 07:08 PM
hkunz's Avatar
The narrowing is the part that sucks. A Ford 9" out of a Mustang or Cougar would fit, that's what I run in my 69. If you can't find one in the junkyard, call Currie Enterprises. They don't just have the high dollar stuff, they also have less expensive options. From a junkyard, you just have to get the axle flanges redrilled for Chevy pattern, cheaper and easier than you might imagine.
Old Oct 18, 2010 | 09:16 PM
Its got a 10 bolt.
Old Oct 18, 2010 | 09:19 PM
Thanks, I run into a lot of ford 9" rears on craigslist . Gonna look into that.
Old Oct 19, 2010 | 12:20 AM
I don't mean to brag, but I've got a 9" also.
