Couple questions
Old Aug 21, 2007 | 05:38 PM
02blackonblack's Avatar
Default Couple questions
I have an 86 IrocZ with a 305tpi.
First, I do not have the stock timing cover with the tabs and I need to time my car better than by ear. What can I do? (I do have a timing gun)
Secondly, my oil pan is bent in a little bit from previous owner. Oil does shoot up under my valve covers and my gauge usually reads a little less than 30psi, but very rarely does it get over thirty. Isn't it supposed to get to 60 when driving?
Old Aug 31, 2007 | 12:30 PM
t9ojetpilot's Avatar
Default RE: Couple questions
[&:] your motor should have come with the timing pointer kind of behind the water pump to verify find tdc on #1 cyl and see where zero mark on dampner is. youll need to get another timing cover with the proper timing marks and make a template to identify tdc then just work off that or get an aftermarket pointer for future reference if your oil pres reaches 30 your probably doing alright for an older motor 60 for a newer motor or when its cold with a heavy weight oil would be close to normal
chase0990
Jul 11, 2010 10:08 PM
toxicat
Apr 6, 2009 01:29 AM
rpope904
Jul 6, 2008 04:11 PM
whammer3024
Aug 20, 2007 10:03 AM
redt_top
Mar 14, 2007 11:00 PM
