Car totally dead
Old Jul 6, 2007 | 04:15 PM
HotRod2000's Avatar
Default Car totally dead
I searched and couldn't find my problem so I'm starting this new post. I have a 2000 Chevy Camaro V6. In January it was mostly parked and I would start it up every week. In February we had a real bad ice storm so I went about 2 weeks without starting it. After the ice was gone I started it and NOTHING, totally dead.
I bought a brand new fully charged battery and now the alarm light comes on and the door/keys in ignition dings at me. Everything else is DEAD. What do you guys suggest I look at next? I need to check the fuses again, someone told me you actually have to pull them out to check them. I only glanced yesterday. Thanks guys!
Old Jul 6, 2007 | 04:19 PM
badinfluenceRS's Avatar
Default RE: Car totally dead
are the terminals hooked up good, and free of corrosion?
Often you can get a little power to allow various functions to work but not enough juice to start the car...
Use a metal brush to clean the battery cable connectors, if that does not work, double check that the battery is charged and then move on to the starter selinoid and such...obviously you might want to check the ignition fuse first
Old Jul 6, 2007 | 04:39 PM
HotRod2000's Avatar
Thanks for your quick answer, the positive connection wire has a little rust, do I need to WD40 it?
Old Jul 6, 2007 | 04:49 PM
I use a metal brush or a little piece of sandpaper...
Old Jul 6, 2007 | 04:54 PM
bluovlh8er's Avatar
WALMART SELLS NEW ONES.
Old Jul 6, 2007 | 05:07 PM
HotRod2000's Avatar
Ok, thanks for the info! If I can't get it running by Sunday. I'll be back!
Old Jul 6, 2007 | 05:59 PM
Make sure the security lite is off when you try starting the car, otherwise you will be wasting your time and money.
Old Jul 6, 2007 | 06:22 PM
HotRod2000's Avatar
How do you turn off the security system?
Old Jul 6, 2007 | 06:29 PM
The security system terns off automatically when you put the right key into the ignition switch. If the lite stays lit the car will stay dead.
Old Jul 6, 2007 | 06:43 PM
HotRod2000's Avatar
So I need to start the car when the light does not blink? Is that what you meant? Because it keeps blinking.
xcorat
Aug 27, 2009 10:25 AM
MochaCaliGirl
Aug 15, 2007 06:38 PM
