cant seem to get info~!
Old Oct 19, 2009 | 09:55 AM
redhoss02's Avatar
Default cant seem to get info~!
i have a 1988 irocz z28 that i am re-furbishing! i started with pulling the 305 tpi. i bought a 350 long block and installed everything from the 305 onto the 350. the 350 has been dropped in and the motor mounts are bolted up thats it. im trying to hook up all the sensors and vacuum lines and all connectors on the wiring harness. i have already installed 24lb injectors and i am trying to find a 350 chip for the ecm, knock sensor and module. i was going to see if there was any way you guys can hook me up with some under the hood pics and close ups of the sensors and along the tpi so i can see where most of this stuff hooks up to. i know this might be a pain in the a$$ but it would really help me out big time. my setup has the cold start injector on the driver side and i found where those connections go but on the passenger side there are also 5 connections and i only have 4 injectors???? any help will be greatly appreciated. this was a project but im trying to get it running asap as a daily driver and do the mods as i go. thanks a million guys!
RodneysPhoto
Mar 28, 2011 01:44 PM
camarogurl843
82-92 V6 Tech
Nov 4, 2010 02:44 PM
Skidoo03
Oct 18, 2010 06:39 PM
Homestar1217
Jun 27, 2009 08:37 PM
vinnyboombots
Apr 4, 2009 03:14 AM
