Caliper Info
Old Nov 29, 2009 | 12:49 PM
Cammy 3.8lV6's Avatar
I guess I'd better go double check that then lolz!! Seeing as its snowing outside right now though means the snow/salt is on it's way I may just store her for the winter and worry about this next spring.
Old Dec 17, 2009 | 02:16 AM
Varaneirm's Avatar
Default Caliper Info
Ok, so I pulled the wheel and it looks like the rotor doesnt seat as far back as it should, and that why it rubs on the caliper. I f I push and pull on the hub theres no play, but if I wiggle side to side or up and down there is a significant amount of play. Since I did the bearing, its not unlikely that I screwed it up, but could it be the hub or trailing arm worn and if so could I tell with a visual inspection?thanks
mab6680
Mar 10, 2014 07:49 AM
Craig80RS
Jul 23, 2013 09:08 AM
silver97
Aug 24, 2011 04:32 PM
02blackonblack
Nov 22, 2006 01:36 AM
