A/C delete
Old Nov 21, 2008 | 04:58 PM
panhead's Avatar
Default A/C delete
What size or lengthbelt would i need to delete the A/C compressor? How would i route it?
Old Nov 21, 2008 | 06:05 PM
Default RE: A/C delete
No mention of the year, No mention of the engine size, I would guess the belt is between 108" & 52" and it would route just like the old belt except not around the AC unit.
Old Nov 21, 2008 | 06:15 PM
95slvrZ28's Avatar
Or you could get an AC Delete idler pulley and run the same length belt. We may be able to let you know what's available with the year and model of your car [8D]
Old Nov 21, 2008 | 06:28 PM
MadMikeZ28's Avatar
ORIGINAL: panhead
The answer is...................Four [8D]
Old Nov 21, 2008 | 08:21 PM
panhead's Avatar
lmao sorry. 96' Z28and i don't want to do the pulley just a shorter belt. And yes i know i could use string to measure but figured someone had already done it and could save me a little time and pain of taking things off and out of the way before i'm ready. But before i get some more "SMART" answers i'll just take it apart and walk to the parts store[:@]
Old Nov 22, 2008 | 10:02 PM
95slvrZ28's Avatar
Just out of curiosity, why are you doing an A/C delete anyway? Just trying to ditch the extra ~20 lbs of the A/C system?
Old Nov 23, 2008 | 08:39 AM
panhead's Avatar
4 reasons really. I just got the car and the compressor is bad, little extra power, weight, and i don't use it anyway.
Old Nov 24, 2008 | 12:51 PM
95slvrZ28's Avatar
Well, I can understand the weight aspect, but you don't have any decrease in power unless you're using your A/C, otherwise it just acts as an idler pulley. I hope you don't use your defroster either since that uses the A/C unit to pull moisture out of the air.
Old Nov 24, 2008 | 01:00 PM
Saint_Ali's Avatar
A/c is for pussies!
mike6208
Jan 22, 2012 08:52 PM
skinut
Jan 4, 2012 05:50 PM
Yooper Z28
Jan 1, 2012 12:45 PM
wthile
Apr 14, 2008 08:45 PM
DRI_Z28
Jul 12, 2006 01:18 PM
