Another Problem...
Old Jul 23, 2007 | 11:55 AM
jdubs1813's Avatar
Default Another Problem...
Cars running and is timed right. However, it just isn't running right. There is a constant clicking noise coming from the engine. It accelerates pretty good until around 3500 rpm and then it takes a crap. Doesn't accelerate at all and kind of hesitates ataround these rpms. Anyone have any idea what this is?
It's a 1989 Camaro 305 5.0L TBI.
Old Jul 23, 2007 | 12:59 PM
Default RE: Another Problem...
The clicking may be a rocker arm that needs adjusting. ora bad lifter, or even an exhaust leak. The fading away at 3500 RPM could be due to a fuel problem such as bad fuel pump or dirty fuel filter, a clogged air filter, or a clogged cat.
Old Jul 23, 2007 | 04:24 PM
jdubs1813's Avatar
For rocker arms, how tight is it supposed to be? I've heard you're supposed to slowly tighten it until you feel a real little resistance, the go 3/4 of a turn tighter. Is this true?
Old Jul 29, 2007 | 09:49 PM
t9ojetpilot's Avatar
[X(] thats close, you need to make sure you are on tdc for each valve you adjust this way. bring to tdc for given cylinder and rotate push rod with fingers and tighten rocker arm nut until a resistence is felt then tighten another 1/2 to 3/4 turn. 1/4 turn of the crankshaft will get you to the next cylinder in the firing order kurt
Old Jul 29, 2007 | 10:00 PM
ORIGINAL: jdubs1813
Thatis true as long as the lifter is pumped up. If you adjust the rockers when a lifter is collapsed, when the lifter eventually pumps up, the adjustment will be too tight and the valve will stay partially open.
IROCYOURVTEC
82-92 V6 Tech
Oct 20, 2010 01:01 AM
Beest
Jun 27, 2010 02:42 AM
IZZY1967RS
Jun 15, 2008 11:11 PM
2lucke4u
Sep 1, 2006 09:55 PM
