aluminum drive shaft
Old Nov 11, 2006 | 04:39 PM
Saint_Ali's Avatar
Default aluminum drive shaft
i was looking at getting an aluminum drive shaft, but i read the it may not be good to lower weight from the drive train, what are the benefits of getting it ? will it transfer power to the wheels better than the stock one ?
Old Nov 11, 2006 | 06:50 PM
blackz87's Avatar
Default RE: aluminum drive shaft
Not big performance item to add horsepover, just reduces rotating mass in the drivetrain, It is a nice upgrade, I have one on my car. 1Le 2 3/4 dia & LS1 4 dia are both good choices, just do not pay over $150 for one.[sm=gears.gif]
Old Nov 11, 2006 | 07:28 PM
94Z28SHAKER's Avatar
and they also help to reduce vibrations common to LT1's at above 60 mph
Old Nov 11, 2006 | 09:15 PM
shnormo's Avatar
It is lighter. When building a race car, shaving weight as much as possible is your goal. It will help transfer the power more efficently. Aftermarket drive shafts are held to a tighter balancing specs.
Old Nov 13, 2006 | 09:44 PM
uncle bill's Avatar
The key is unsprung weight. Half of a driveshafts weight is unsprung ( weight not held up by the springs ) Racers go ga-ga for unsprung weight be cause it's an 8 to 1 ratio for removing weight. IE: 1 pound of removed unsprung weight equals 8 pounds of sprung weight. Important stuff.
BloodDragon
Apr 21, 2013 11:37 AM
CamaroDreamer
Feb 19, 2011 05:32 PM
97blackcamaroRS
Oct 3, 2010 10:59 PM
Liferollson9987
Aug 17, 2007 06:00 PM
found69
Oct 9, 2006 01:50 AM
