Adjust Speedo on 1993 C3500
need to pull the speed sensor and see if you have gears in there. http://www.transmissioncenter.net/sp...n_______va.htm
lol dont have a book for the 93, mine is a 97, 93 would be obd1 so im thinking it would have a trans control module of some sort. ahh here is something on it. How to Recalibrate/adjust your speedometer
You have to pull the inst cluster out and install a chip into a socket on the back of the inst cluster.
Any GM dealer will have it, Speedometer Calibration Kit, does two vehicles.
Comes in a package, two chips, a harness to literally 'burn out' a solder run on the board, and instructions on total usage of the kit and in clipping off the supplied chip legs to a corresponding gear ratio and tire size, all of them being OE size, of course.
Chevy wanted $350 to do it.
Actually one deal said sure no problem, will will reprogram it for $95. They never asked me the year. The just assumed it was ODBII
One told me it was impossible... and one told me they could replace the drac unit.
I just bought one of these. Superlift Part No. 33003 - Truspeed Speed Sensor Calibrator Kits
It is a superlift TruSpeed calibrator.
I remember these coming out in the 90's
I heard they worked.
