99' Tahoe electric window
Old Jun 3, 2007 | 09:27 PM
68RSSScamaro's Avatar
Default 99' Tahoe electric window
Anyone have the solution to troublesome electric window problems on a 99 Tahoe?
Passenger side stopped working:
1) All fuses checked good
2) Power at the swich - Good
3) Power at the motor - Good
4) Assembled everything and the window starts working again.
Today the driver side window will not operate - Do you think its the switch, electric motor, or loose conection?
Thanks In Advance
Old Jun 3, 2007 | 10:43 PM
MadMikeZ28's Avatar
Default RE: 99' Tahoe electric window
Both windows did not work and one switch unit works them both. I would go for a switch. Its cheaper and easier to start at. What screws you is I have seen power go to the drivers side switch and then to the other windows from it. When the drivers side went bad it woulsd stop the other windows from working. Plus that is the switch that gets a lot of use.
Old Jun 4, 2007 | 08:02 AM
williesrepair's Avatar
Also keep a eye out for broken or almost broken wires in the door jambs. Not a usual problem on Tahoe's but never say never.
Guesstimate, do a switch first as suggested, then go from there.
Old Jun 4, 2007 | 06:40 PM
Will do...
Thanks guys!
voxeltoxin
Jan 12, 2013 06:31 PM
99 camaro T-Top
Oct 3, 2010 02:16 AM
camboltz
Jul 25, 2010 07:20 PM
911eze
Apr 11, 2005 01:53 PM
