95 3.4 starting issues
Battery was getting weak on my car and the starter was beginning to drag some so i replaced the battery. Went to start it afterwards and everything lights up as far as the normal lights go but when I completely turn the key nothing happens. The starter wont engage or turn over or anything. I checked most of the obvious such as fuses and grounds that i know to check and still no cranking. Tried jumping the starter and the ac compressor clicks but the motor wont turn over. HOWEVER nothing at all happens when i use the ignition to engage the starter. The security system has been disengaged for a while so i dont think it could be that but then again i dont know. Thats why I am on here buggin Yall lol PLEASE HELP
double post,
check for power at the big post, should be hot at all times. the s post is for the ignition (you didnt hook it to the wrong small post did you) and should have power when the key is turned to the start position.
double answer,,, lol welcome to the forum.
