94 LT1 with no heat and other cooling issues
Old Apr 9, 2011 | 09:39 PM
76flh72xl's Avatar
Default 94 LT1 with no heat and other cooling issues
I just bought my 94 LT1 2 monthes ago. i was having overheating issues wich led me to replace the radiator, upper and lower hoses, and replace the stock thermostat with a slp 160. I also pulled the knock sensor and the drain plug to completley drain the dexcool, and replaced with a new knock sensor and regular green prestone 50/50. Now the car runs a constant 170 or so when cruising and maby 200-220 when stuck in traffic wich is very acceptable, but i still have no heat and the overflow is filling upand the radiator is going low. the low coolant light came on once, i have checked the radiator multiple times and it is always about half a quart low. i have bleed the system multiple times and have good fluid coming out. So i figure i have to replace the heater core to fix the heat, but dont know what to do about the coolant, is this normal? or do i have a bigger problem like a bad head gasket? any thought or advice would be appreciated.
Old Apr 13, 2011 | 11:28 AM
are you seeing coolant on the passenger side floor or under the car on the passenger side behind the front wheel? would be best to rent a cooling system pressure tester from the local parts store and do a pressure test on it. should be able to pressure up the system and find the leak that way. i had a hose leaking at a hose clamp but only leaked at certain times, never in the garage. i pressured the system and went around to all the hoses moving them, pulling and poking, and found a small hole by one of the clamps.
Nas Escobar
Jan 20, 2014 01:53 PM
ksink7
Jan 11, 2014 12:47 AM
shrews61
Apr 30, 2013 09:59 AM
Catmaigne
Jun 19, 2011 11:16 PM
mychevy85
Jul 2, 2006 11:37 PM
