92 rs to z28 Rearend swap
Well if you are buying the Z28 rear axle I would open it up and check what gear ratio (stamped on OD of dr gear) and check for a Limited slip ( check picture). I would not waste the money if it is a 2:73 like the one in the RS. They are both 10-bolts and will bolt right in. You did not give a lot of info on the Z28 rear axle to really give you a good opinion if it is worth it. Ratio, brakes and etc.
Only ratios available (year unknown) that are improvement are 3:23 & 3:42 (10-bolt)....
