84 Z-28 305 to 350 motor mounts?
Old Sep 19, 2007 | 07:30 PM
speeddemon71's Avatar
Default 84 Z-28 305 to 350 motor mounts?
which motor mounts can i use to do this conversion? i also was wondering what powersteering pumps will interchange with the 305 pump it went to **** i need a new one so i was wondering if the v-6 pump is the same? also i have a 700r4 street and strip tranny i wonder if i should go to a 5 speed? well get back to me
if you can help.
thanks
Old Sep 19, 2007 | 07:57 PM
blackz87's Avatar
Default RE: 84 Z-28 305 to 350 motor mounts?
Motor mounts are the same for a 305/350......
The pump is the same for both 305/350......V-6 one?????
Stay with the 700R4 and forget the 5sp.....
Old Sep 19, 2007 | 08:00 PM
t9ojetpilot's Avatar
[&:] motor mounts should be the same and most likely the ps pump will be a match but check both of these with your local parts house. the manual vs auto is a preference and application thing. i prefer an auto for drag, cruising and all around but the manual may excel in the road courses but suuuuuck in stop and go traffic if you weekend warrior is also a daily driver kurt
Old Sep 19, 2007 | 08:05 PM
well i went to put the moter in and one side will not fit i got so pissed off
and i ment the camaro with a non v8 on the pump
i think i will stay with the auto i will need a new shifter tho they break at the top
Old Sep 19, 2007 | 09:08 PM
does it matter that the motor came out of a van does the van have different motor mounts not sure?
Old Sep 21, 2007 | 12:18 AM
[&:] chevy did use 2 or 3 different motor mount set ups for v8's and i would venture to guess that van and maybe truck ones are different than the car version, let me guess theyre off by less than an inch but just wont line up??
Old Sep 21, 2007 | 04:56 PM
yep just an inch or so
Old Sep 22, 2007 | 01:53 AM
[&:] you need to match the rubber portion of the mount to the steel portion that either bolts to the block or to the frame. in other words one of the other types of mounts. ive been thru this myself. most cars came with a mount that had the rubber portion bolted to the block. vans and trucks usually had a solid steel piece bolted to the block and a captured rubber mount bolted to the frame and it sound like you trying to mix those two incorrect halves or using one of the few different incompatible sizes kurt
motoxraca33
Jun 2, 2010 09:59 PM
countryboy0158
70-81 V8 Tech
Feb 19, 2009 10:01 PM
shippy8907
Dec 26, 2008 08:42 AM
hatchetman1025
Sep 8, 2008 02:30 PM
super sport
Oct 7, 2006 02:30 PM
