Motor Mounts
Old Jan 8, 2009 | 08:29 AM
countryboy0158's Avatar
Default Motor Mounts
i've got a 76 camaro that i plan to put a 454 into but i'm not quite sure what i need to do for motor mounts and i was hoping that some of you guys could help me out... the car has a 350 in it right now but i'm sure i'll still have to swap mounts
Old Jan 17, 2009 | 03:02 PM
c'mon guys help me out a little... are there any mounts i can pull off another car or do i have to have some made or what?
Old Jan 31, 2009 | 01:02 PM
Zsnoop's Avatar
A set of '74 big block chevy pick-up mounts will work. The only obstruction is by the A/C evaporator. The hand-like protrusion will have to be cut off and fiberglassed. The exhaust is another malady. Manifolds will fit for sure. Headers ? you're on your own.
Old Feb 19, 2009 | 10:01 PM
johnson73801's Avatar
i did the swap from a sbc to a big block the same mounts that you have on the 350 will fit the 454 just fine. and i would get a set of headers summit has a pair for like 90 bucks if i remember right i the the # was G9011. and if your frame still has the bars that goes from the engine crossmember back to the frame rails you better take them out or it wont fit..
motoxraca33
Jun 2, 2010 09:59 PM
r6rider
May 8, 2010 08:35 PM
shippy8907
Dec 26, 2008 08:42 AM
hatchetman1025
Sep 8, 2008 02:30 PM
super sport
Oct 7, 2006 02:30 PM
