327
Old Jul 16, 2005 | 08:56 PM
damin38x's Avatar
Default 327
willa gen1 327 fit into a 98 camaro under the stock hood??
Old Jul 16, 2005 | 09:18 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
Default RE: 327
dont see why not. buy why would you do that??
Old Jul 17, 2005 | 09:31 PM
JD1969's Avatar
Default RE: 327
Depending on the intake you run yes it might. You will need to trim around the cowl area. I am not going to question why you want to do this but just know that an LS1 will make a ton more power cheaper than an old school 327. I you are going to go carbed I would at least build a stroker small block, or Edelbrocke has a nice dual plane carb intake for the LS1 and MSD now has a system to fire it .
Old Aug 7, 2005 | 04:45 PM
Default RE: 327
It will probably fit if you leave out the carburator or make a hole in the hood and make room for the distributor in the firewall. But why do this when the stock LS1 ia much better engine.
