3:42-3:23 gears
Old Jul 30, 2011 | 04:31 PM
Stevolwevol's Avatar
The phrase "old school" is warn out, but that's where I came from. For the life of me I didn't know the speedometer was computerized, and not gear driven.
Old Aug 8, 2011 | 08:53 PM
NIKONI's Avatar
There are only two four letter words that are offensive to men
-'don't' and 'stop', unless they are used together == 'don't stop'!
( just a joke )
Last edited by Camaro 69; Aug 8, 2011 at 10:37 PM. Reason: spammertising hyperlinks
Old Aug 27, 2011 | 02:21 PM
!WildChild!'s Avatar
Your speedo will be off by 3.5 mph. Add that to what the needle is showing to get your actual speed.
this is how you get a ticket...its off by a percent not an actual number...maybe 3.5 @60 MPH...but if you are going 2 MPH you are not in fact going 5.5, if you have a GPS app or unit you could measure it that way and get some hard numbers till you get it corrected...
Old Aug 27, 2011 | 09:21 PM
For some reason I had thought he had mentioned a speed in his question, but yes the difference I was referring to is highway speed. I am aware it's a ratio (%) and not a set number. A difference of 3.5 mph @ 60 is negligible, and cops around here don't even give a second look until you're going closer to 10 over. You can use that small difference as a "buffer zone" (follow the speed limit on your speedo and you're golden), as long as you keep your wits about you.
Old Aug 27, 2011 | 09:40 PM
I'll trade cops with you. Around here the suck. Suck CoQQ!
Old Aug 27, 2011 | 10:02 PM
Maybe they just "got your number"! Easy mark coming....10-4.
sepadowd
Aug 4, 2011 07:59 PM
91camaro350
82-92 V8 Tech
Aug 5, 2010 10:28 AM
gfrench
Jun 19, 2010 10:16 PM
1bad96Z28
Jun 9, 2007 09:12 AM
