1971 camaro Help
Old Aug 2, 2008 | 06:23 PM
Billy Z's Avatar
Default 1971 camaro Help
Car has a 350 auto-trans. Car cranks but will-not start, Replaced Ing. Coil still not starting. Any HELP PLEASE.........
Old Aug 3, 2008 | 02:57 PM
73camaroSS's Avatar
Default RE: 1971 camaro Help
is it geting fuel,is it getting spark,those are things you need to check for.
Old Aug 3, 2008 | 04:21 PM
JRs72RS's Avatar
February 2009 ROTM
73CamaroSS is right, you need to isolate the problem. Check for fuel, when you move the throttle does the accel pump squirt gas? Pull a wire off a plug and check your spark. What type of ignition do you have? Points, check the points and the condensor, dirty points or a shorted condensor will stop the spark. HEI, check the inside of the cap for carbon tracking, the center of the rotor for burning, check the continuity of the wires to the module, they are known to break from flexing with the vacuum advance, connect an ohm meter to the pickup coil you should get 500-1500k reading on a good one. If all else fails get the module checked, many times I see modules installed without thermal transfer grease, this will cause them to heat up and die.
Old Aug 3, 2008 | 08:03 PM
Billy Z's Avatar
Carb. is getting gas. Will have to pull a spark plug to see if its sparks.....
Vicious71
Nov 10, 2010 12:03 AM
Dstryr
May 21, 2007 06:27 PM
Bzman
May 5, 2007 10:56 PM
rat454
Feb 9, 2007 07:47 PM
