1967 Camaro Disc Brakes
I am installing a new disc brake kit onto my 1967 Camaro SS and wondered if I should replace the ball joints while I have the spindle removed. The top and bottom feel tight but seem stiff to swivel. If I do replace the joints, what special tools will I need other than the splitter fork. I was going to go for the 2" dropped spindles but my tires would be really close to the fender well. Is cutting a coil or two off of the spring considered a bad thing to do? I only want to drop the front about an inch. Thanks!!!
RE: 1967 Camaro Disc Brakes
depends if the balljoints have been changed before, they should be tight. you can cut one coil to lower it safely. I cut one coil off of mine. I love the way it looks. you can see mine here if you like
http://pg.photos.yahoo.com/ph/firebi...acer/my_photos
