100 octane
[&:] this will hold true for all engines. if it does not knock then the octane your using is fine but be sure you know what to listen for cause if its doing it the computer retards timing losing power and the detonation part tends to blow holes in pistons if allowed to go on for too long. in other words you cant go wrong with a higher octane (within reason) it just costs more kurt
ORIGINAL: t9ojetpilot
ORIGINAL: SpecterGT260
same. not sure when they started using knock sensors, but all new engines will have them
ok ok ok, im speaking too generally ![EEK!](https://camaroforums.com/forum/images/smilies/eek.gif)
the point is dont rely on sound for a newer engine because chances are the engine isnt knocking anyways, its just been retarded to the point the percieved knock went away, thus addressing the OP's question. oh, did I mention: "
On a stock motor, whatever it may be, it's dumb to run anything over 93 octane because the manufactures make sure you can run on regular pump gas, no need to run 100+ octane in an LT1 or a 3.8L...c'mon guys, use your heads!
ORIGINAL: Iceman1023d
alright... because i've just been runnin 93... and i'll probably run 100 or somethin after i replace my bad o2 sensor thatwas supposed to come in the mail a few days ago
#20
[&:] wholy crap batman its kinda all over the board here. specter my second post was in reference to my first ,Not your posts. knock sensors have been around for awhile and unless im mistaken a knock must first occur before KR happens which translates into you should be able to hear it happen. and for all those frontin high HP numbers with super cool exhausts that are too loud to hear any knock maybe you should be more in tune with your hot rod to tell when KR is droppin your HP or at the very least make a run or two with a scanner hooked up to see if detonation and KR are occuring to avoid holes in the super HP pistons. really folks detonation is not a silent killer it makes itself known in both computer and non computer motors and if you cant tell when its happening you need to spend more time with your favorite motor. 92-93 octane will take care of most streetable built motors, 100 would be overkill. as for o2 sensors and lead.... well im not aware of any gasoline produced anymore that contains enough lead to damage much of anything let alone an o2 sensor. they really dont like antifreeze and some goops and goo's but most of those have been eliminated from the industry(noncompatible goops, goo's) since o2 have become the norm
