02 sensor question
Old 08-01-2010 | 06:17 PM
1983camaro's Avatar
Default 02 sensor question
its not about a camaro but wrather an S10. threw a code the other day that ended up being the 02 sensor after the cat. when i went to remove the old 02 sensor i took an open end wrench and with a couple wrenches on it i though i got it, but sadly found out that i rounded the head off the 02 sensor. whats the next step for me?
Old 08-01-2010 | 06:26 PM
Cut the wires off and use a 6 point deep socket, it should be able to get a good grip even with the rounded off edges.
Old 08-01-2010 | 06:30 PM
1983camaro's Avatar
that made it worse lol. an impact wrench wont even move it. tommorow im goin over to my friend's ( who is a mechanic) house. maybe he'll be able to do something for me. thanks for the help though
Old 08-01-2010 | 07:46 PM
osduck5's Avatar
I had one do the same on me the other day. Unfortunately it was on the exhaust manifold and I ended up having to remove the manifold to get it out. It was crossthreaded. I used PB blaster, heat, everything I could but nothing moved it until I laid the manifold on the ground, had someone stand on it while another person put the hurt on it with a breaker bar attached to a 6 point. Good luck.
Camaroboi22
02-26-2013 10:49 AM
Krusher RS
01-15-2013 09:23 AM
Chevy101
07-09-2011 08:07 PM
hevymetalg
09-25-2008 06:50 PM
cwj82052
06-29-2008 12:31 PM
