General Racing/Tech General talk about Racing or help setting up your car
went to the track (disapointed)
Old Apr 25, 2009 | 09:03 AM
kirks11's Avatar
Default went to the track (disapointed)
so last night was the first time i have ever made a pass, i was wanting elevens but my car failed to upshift at WOT, also i didnt leave very hard. so the best i could pull out was a 12.2 at 113, i know i could have gotten 11's easy, but here is my slip results
r/t .597
60 1.928
330 5.236
1/8 7.940
1000 10.292
1/4 12.2
mph 113.2
Old Apr 25, 2009 | 09:44 AM
z28rob18's Avatar
so are you dissapointed that it wouldnt shift right or? whats mods you hav?
Old Apr 25, 2009 | 10:11 AM
kirks11's Avatar
its an a4 i have heads cam intake stall shift kit, DR's
Old Apr 25, 2009 | 10:37 AM
z28rob18's Avatar
wat about headers cat back cai and all the bolt ons? if its heads cam wit no bolt ons that could be about right. tuned? wat heads and cam?
Old Apr 25, 2009 | 01:17 PM
kirks11's Avatar
yeah i have all the supporting mod for the heads and cam.....my car would just not shift it hit the rev limmiter prolly 4-5 times then shifted.
Old Apr 25, 2009 | 09:06 PM
YoungDriver's Avatar
It's not shifting because I'm guessing you didn't get it tuned after you got the heads and cam. So your computer won't shift faster now that it has more power and speed. You should send it in to www.pcmforless.com and have them do it. Cheapest and best way, unless you have a dyno somewhere close?
Old Apr 25, 2009 | 09:28 PM
TheStig's Avatar
For the kind of power you have, which is a lot, you should be well into the 11s. Some people are in the 9s with heads/cam and stock bottom end. You should get some stickier tyres. I'm getting 2.0 60' stock with street tyres, you should be getting a bit lower. You should also have a stronger rear end to deal with launching all that power.
Your shifting problem is probably the trans freaking out because your sending 500+ HP through it on a stock tune. I would recommend a dyno tune.
Old Apr 27, 2009 | 04:31 PM
kirks11's Avatar
the car is tuned altho im gonna get it retuned cuz the tune on it right now sucks, i think it might be the lever arm in the trans
Old Apr 27, 2009 | 07:35 PM
SpecterGT260's Avatar
Ninja Administrator
stig, the guys running low w/ stock bottom ends NA have ridiculous suspension and weight reduction done.
what about a shift kit for the OP?
Old Apr 27, 2009 | 07:56 PM
TheStig's Avatar
Well yeah, but you should still be doing better than 12.2 w/ heads & Cam LS1.
