General Racing/Tech General talk about Racing or help setting up your car
supercharged gtp or a 74 cam 350 vortec?
Old Mar 16, 2007 | 01:57 PM
74_camaro's Avatar
Default supercharged gtp or a 74 cam 350 vortec?
ok right now my buddy just keeps doggin on my car. wont give it any respect so after my new motor is all broke in we are going to race his 2004 supercharged gtp and my newly rebuilt 350 vortec. he will be pushing out 260 hp and 280 tq. and he only weights 3,477. now my car just having the motor finished up. i put the vortec heads back on just polished up, the lifters internals are all the same as before except the cam is 496 intake 510 exhaust. new transmission for harder shifts. dont have posi so im only gonna have one tire spinning. not sure on my rearend havnt check it out yet but its nothing that strong. but i know he is going to run low 15's but before my car was running like crap and ran a 17 even but now i have a tune up done. a little polish job and the new cam just wondering if i stand a chance in hell or not?
Old Mar 16, 2007 | 10:22 PM
coprunr's Avatar
Default RE: supercharged gtp or a 74 cam 350 vortec?
if you have a good intake (which almost have to have a decent one because of the vortec heads) a good carb and ignition system you should be making 275-300hp minimum as long as your heads are L31 Vortec heads (only 8 intake bolts 4 per side going straight up and down) and not the old TBI Swirl port heads that people like to claim are vortecs). the L31 Vortec heads are the best flowing production cast heads period. they even outflow most aftermarket cast heads and several aluminum heads. those heads are easy to make power with , and horse power is made in the heads and camshaft. another thing you mentioned is the cam speaks...a true Vortec engine has a roller cam and the valve springs will not hold more than .450 lift because the springs bind (they all get stacked and can compress no more) , with LS1 springs you can run .550 lift and then the rocker hits the guide with stock spring pockets.
Old Mar 19, 2007 | 01:04 PM
74_camaro's Avatar
ORIGINAL: coprunr
ya it has the roller cam. buti didnt know that about the springsthe only thing i was told is that my brakes might be a bit tough. but noone i knew said anything about the springs.
Old Mar 19, 2007 | 03:24 PM
badinfluenceRS's Avatar
I thought the sc 3.8's put out 240hp...
Old Mar 19, 2007 | 08:37 PM
74_camaro's Avatar
ya i have found a few different site/ where it says either 260 or 240 so im not sure on the specifications.
Old Mar 19, 2007 | 09:27 PM
JD1969's Avatar
Is the GTP stock? I have seen stock ones in the 14's and lightly modded ones run high 13's.
Old Mar 20, 2007 | 12:17 PM
74_camaro's Avatar
ya it would be stock supercharged
Old Mar 20, 2007 | 09:14 PM
JD1969's Avatar
I think it will be a good race, too close to call. I hope you win.
cmchambers7
82-92 V6 Tech
Mar 22, 2011 05:29 PM
sprtsfrk
Oct 28, 2007 06:31 PM
aj69z28
Sep 27, 2006 07:21 PM
94CamaroSFI
Sep 3, 2006 12:04 PM
