General Racing/Tech General talk about Racing or help setting up your car
Sick's Misadventures
Old Jun 8, 2006 | 09:44 PM
TimmyTheWop89's Avatar
Default RE: Sick's Misadventures
your a stock civic. yea what are you gonna do about it.
Old Jun 10, 2006 | 02:51 AM
STANMAN's Avatar
Ok, I will actually help Sick here. Your carb is to big for your application, unless your 305 is highly modded. I had a 650 on a 340 (an enigne actually built for racing) and it was more than enough, on a 305 it's probably overkill. And the tunnel ram is harming you, again, overkill for your application.
There, I added something valueable to the conversation. Happy??
Old Jun 10, 2006 | 03:00 AM
STANMAN's Avatar
More help. From your symptoms I would get an MSD coil and wires (I think just thier SRT coils are ****, heard good stuff about their other products) and gears. Sounds like the biggest bang for your buck.
Old Jun 15, 2006 | 05:42 PM
mattvogt's Avatar
Keep the tunnel ram since I saw your engine build online and it is built. One hell of an engine. Plus the carb is fine on there.
Good luck
Old Jun 16, 2006 | 02:44 AM
STANMAN's Avatar
I haven't seen his engine build, I was just going on the fact that people never choose to really build up 305's, they usually pick 350's. If it's a built 305, the carb may be fine, but I still think the tunnel ram is overkill.
Old Jun 16, 2006 | 02:10 PM
Patrick's Avatar
Administrator
was your 340 stock? im was running a 750 with huge jets and nozzles on mine
Old Jun 16, 2006 | 09:00 PM
SickSickSick's Avatar
just for the sake of being civil ... the only thing stock is the heads. its a 305 bored .060, 305HO flat top pistons, .480 lift 304 duration speed pro cam, msd pro-billet distributor, full length headers, holley 600 CFM VS. i replaced the weiand dual plane with the TR1-x tunnel ram and gained a second so i know that wasn't a bad move. i thought i was running 3:73 gears. had never pulled the pan and actually looked. took a peek last week and found 3:23. explains alot about my times. found a set of 4.11 and put them in today. got a mini spool coming in the mail. since the last time i ran it i've lost a couple hundred pounds, done away with all the belts and pulleys, and got the 4:11 and the locker. would like to see it turn a low twelve before i put slicks and nos on it. been ordering some nos parts off ebay. going to build a wet nos system for it. like the rearend build it will be a first. i don't know which gives me more pleasure. building it or putting my foot through the carb. sick
Old Jun 16, 2006 | 11:29 PM
STANMAN's Avatar
Remember Sick, only babies need the bottle. Go with an N/A car, and all excuses are out the window, lol!! (otherwise you will always hear, even if you don't spray, that you did, and without it you wouldn't have won, yadda, yadda, yadda. I get it all the time about my SRT, "if it wasn't for the turbo you wouldn't have beat me". Umm, if it wasn't for the turbo it would be a Neon, lol!)
Good job on knocking down those times, keep at it!! Your car would run circles aroun my Mustang more than likely. (the Mustang has the looks though, you have to admit that!)
And yeah, the 340 I had the 650 on was pretty stock. What a great little motor huh??
Old Jun 17, 2006 | 10:40 PM
The long intake runners is just what your engine needs to boost the low end torque. Now you need to get it to the ground.
Old Jun 17, 2006 | 11:23 PM
  #20
tell me about it in more ways than one. its been on jack stands for a couple weeks now ... my accelerator foot is getting real itchy lmao. sick
timmyz28
Apr 7, 2011 05:53 PM
bowtieguy
Jul 12, 2006 12:58 AM
