General Racing/Tech General talk about Racing or help setting up your car
New to the game what should I run?
Old Jan 17, 2010 | 07:45 PM
Hambone's Avatar
Default New to the game what should I run?
I just was given a 1980 Camaro by my dad who is to sick to race any longer. The car is a full street weight car, probably 3500-3800lbs. It was set up for 1/8th mile and was running mid 7's at 91-92 mph.
I was wondering what I could expect to run on the 1/4 mile with it and what would need to be changed..
It has a worked SBC .40 over should be making around 400hp, with Lunati Cams (278/288), Powerglide trans, solid spool 12bolt rear 456 gear I think, tires are 255/60/15 MT's plan on going taller)
Any inputs or suggestions? My dad thinks it may go 11.60's in the 1/4, Im thinking 12.20's...
Old Jan 17, 2010 | 08:07 PM
i would go with some different gears like 370 to 390 range. if u want to drive it on the street go with a posi slug. id say in the low 12s is probly right unless u rev the crap out of it and take the chance of blowin a valve or rod. could also go with a 700r4 built up to handle the hp.
Old Jan 18, 2010 | 12:12 AM
Hambone's Avatar
Well I dont plan on driving on the street much, just the 3 miles I am from the local track..
I do have a built TH400 out of my Nissan I can use, it has an internal transbrake,but I have heard Glides at the way to go if you can..
The motor should rev to 6600-6700 no problem, there is a bunch of headwork done also, i forgot to add..
the bottom end is completely built also..10.3:1 compression, runs on 91 octane..
Also would running race gas or even 100 octane do anything for me or is there some adjustments I need to make..
Forgive me, Im new to the domestic game..
Old Jan 18, 2010 | 04:59 PM
Hambone's Avatar
Does anyone know if going to my TH400 would be better for the 1/4 or will bigger tires get me through on the glide??
Old Jan 18, 2010 | 05:13 PM
if its a race only car then keep the glide. to do the 1/4 i still think the gears are to high,,, or is it low. lol. 411 could do it with a little more tire hight. run it and see what happens. im thinkin ull hit redline way before the line.
Old Jan 18, 2010 | 05:18 PM
Hambone's Avatar
Thats what Im thinking is gonna happen..My dad would run it on the 1/8 and shift at 6200 and cross the trap at 6200-6300 in 2nd. He says the motor will rev to 7000rpms, and thinks shifting at 6400-6500 would make it through the traps at 6500...
Im gonna have to see for myself, but have to wait another 6 weeks for our local track to open..
Im not used to domestics, my Nissan would go 10.0@138 with the TH400, that motor revved to 7500-8000 safely..Problem is if i use my TH400 from that, it was built for a 3.55 final drive ratio..The import guys would always just make more power to go faster, and never looked into proper tire size vs gear ratio...
I know the domestics are set up to optimize the power they make and put it down the track..
Old Mar 2, 2010 | 09:55 AM
Hambone's Avatar
Ok,
Decided to lighten up the car quite a bit. Removed the hood, which weighs about 70lbs, removed fender wheels and all metal supports up front. I had to shave off about 300lbs from the nose.
Im adding a 6 point cage and gonna run 29" MT Drag Radials. Everyone told me I should run about 11.50's with the set up I have..
Old Mar 2, 2010 | 11:46 AM
is it going to keep the front down? u lose time when it comes up to far. its cool but not efficient. let us know how it goes.
Old Mar 13, 2010 | 06:59 AM
Hambone's Avatar
Here are some pictures of the progress of what I have done..Keep in mind I have no plans on restoring this car, but simply using it as a bracket car, so looks are not my big concern. I did manage to remove ALOT of weight from the front bumper and hood. The hood alone weighs about 70lbs, and there is a front bumper support within the front bumper cover that adds about another 60lbs to the nose. All in all I would say I managed to remove about 200-250lbs from the car.
I also relocated the battery to the trunk with a kill switch that cuts the engine and fuel pump from the outside of the car in the event of a rollover or accident. I am adding a 6 point cage and harness within the next week or two.
As far as tires, Mickey Thomson makes a new Radial slick called the ET radial.Its a full slick, with a radial design to compete in radial classes. They come in weird sizes which is what I needed, I opted for a 29.5"x9" tire..
Old Mar 21, 2010 | 05:29 PM
Hambone's Avatar
Well I got 2 runs today, first run wound up deep staging by accident and ran a 12.065@113 with 1.87 60ft.
Second run I staged normally and ran 11.87@114 with a 1.74 60ft..
These were my first 2 times driving the car...
