General Racing/Tech General talk about Racing or help setting up your car
how to race automatic
Old Mar 29, 2007 | 12:06 PM
74454bb's Avatar
May 2007 ROTM
Default RE: how to race automatic
Thats good if you have the computer, but for the older trans with out the shift kits it's faster to do it your self.
Old Mar 29, 2007 | 12:08 PM
Blade's Avatar
June 2007 ROTM
ORIGINAL: Hisss04Cobra
As long as I can remember, I was told to let the computer auto shift it.
I wish JD would chime in.
He's a very knowlegable person.
well if ur normal driving then yes let the computer shift the car.
but if ur racing then u wanna shift it ur self so that u can get most of the gear.
Old Mar 29, 2007 | 03:28 PM
Hisss04Cobra's Avatar
Well, I meant a newer car, like 7745 suggested.
If you have a "newer" car, then leave it in drive.
Old Mar 29, 2007 | 04:08 PM
Blade's Avatar
June 2007 ROTM
newer car that wont matter, ur doing the samething
Old Mar 29, 2007 | 04:25 PM
ORIGINAL: Matts01ES
I'm pretty sure it's best to just leave it in D.
But, I have been wrong before.
Old Mar 29, 2007 | 05:35 PM
The 95 Camaro uses the computer controlled 4L60E transmission. At WOT the computer will shift the transmission tothe next gearat a presetRPM. It does not matter in which forward gear the stick is held in. This avoids damaging the engine by over revving, andsets the shift points for best acceleration.
Old Mar 29, 2007 | 05:41 PM
I knew you weren't supposed to shift it.
Especially for the OP with the 01 Z28, i think he said.
Old Mar 29, 2007 | 10:06 PM
nickdotcom's Avatar
manually shifting an auto car = super dumb
and you can't stall the 4L60E's stock convertor past 1750 RPMs....
Old Mar 29, 2007 | 10:46 PM
JD1969's Avatar
ORIGINAL: z28pete
Thanks Pete, you beat me to it.
Old Mar 30, 2007 | 12:38 AM
  #20
Ratman's Avatar
There are several small things you should establish on the streetbefore going to the strip. Start with a couple of burn outs to check your tire pattern. You may have to run as much as 30 pounds with older polyglass tires in order to get a full width pattern. Heat the tires a least once before launching the car. Practice holding your foot on the brake and torquing the motor against the brake before launching.
This will give you a feel for what ever surface your racing on. Ultimately you will need to learn the feel of your car so that you will be ready for the strip.
