General Racing/Tech General talk about Racing or help setting up your car
Going to the track
Old Apr 21, 2009 | 01:26 PM
fresnoz29's Avatar
Default Going to the track
I'm taking the camaro to the track tomorrow night. What do I need for a catch can? Does a drip pan work?
Old Apr 21, 2009 | 01:57 PM
SpecterGT260's Avatar
Ninja Administrator
its not required, if thats what you are asking.
Old Apr 21, 2009 | 02:41 PM
fresnoz29's Avatar
Ok, thanks. I'm driving 2 hours to get to the track, just wanted to make sure I'm good to go.
Old Apr 21, 2009 | 04:33 PM
Ninja Administrator
if ur talking drag racing, most stock or lightly modified cars get in no problem. they only look for safety equipment w/ higher modded cars. I dont actually know that a catch can is ever required, as it only is meant to remove oil from the intake charge
Old Apr 22, 2009 | 09:27 AM
maudyZ28's Avatar
you dont need one cause you breater for oil is piped into the air intake and the radiator has a coolant bottle. in older cars the breaters are open they need to pipe into a can (literally a can or bottle etc) so it doesn't go on the track if the car pushes oil out. similarly for the radiator, in a closed system they might explode or pop the cap off it the car overheats and spil on track so they need to be piped through into an over flow bottle like in your camaro under the battery!
Old Apr 22, 2009 | 09:52 AM
cbr600rx7's Avatar
He is right on. With latter mods you may need to add a catch can but right now there is no need.
Old Apr 23, 2009 | 05:35 AM
fresnoz29's Avatar
I had a fun night at the track. It was in the upper 90's and there were some some slow times. Most of the ls1's and new body mustangs were running low 14's. I ran 14.2-14.5 at 97-99. I need better tires next time. I was running 225/60-16 all seasons that melted all the way through second gear. All of my 60' times were 2.3-2.7....ouch
Feffman
South
Jun 4, 2015 05:39 AM
Feffman
South
Sep 12, 2014 06:06 AM
Feffman
South
Sep 18, 2013 04:39 AM
Feffman
Mid West
Oct 17, 2012 04:19 PM
Feffman
General Racing/Tech
May 28, 2012 09:39 AM
