General Racing/Tech General talk about Racing or help setting up your car
finally went to track wit n2o
Old Oct 8, 2008 | 12:18 PM
z28rob18's Avatar
Default finally went to track wit n2o
ok so last night i finally went wit the new nitrous system in sprayed a 100 shot my best et was 13.2 @ 111mph. now that not even faster then my best but the mph is really up there? i havnt had the car in the low 13s in over a year its loosing power its old but it will run 13.5s off the juice. so the 13.2 was a bit of a let down i was ready for some lik 12.8s so wat do u think it is? the 60' was a 2.2 which is the usual.
Old Oct 8, 2008 | 12:28 PM
7STANG's Avatar
Default RE: finally went to track wit n2o
Were you spinning hard out of the hole? I would think with your mods you should be in the mid 12's. You should pick up almost a second with a 100 shot.
Old Oct 8, 2008 | 01:07 PM
cbr600rx7's Avatar
with 100 shot you should be picking up more then a .3
Old Oct 8, 2008 | 02:42 PM
98ss4REAL's Avatar
holly ****, you had to be spining the tires. can you lock out first gear (you have a window switch?)? if you do try to lock out first gear thats wat i started with and i still ran a 12.4 with a 75 shot. and a 11.78 on a 100. ur 60 foot looks to be the big problem. wat kinda tires do you have?
Old Oct 8, 2008 | 03:54 PM
z28rob18's Avatar
the problem is my street tires off the line i can get it pretty good in 1st but by peddlin on and off the nitrous but then wen i shift though every gear itll break the tires loose a bit. soi guess i need tires which sux cuz its not in my budget recently cuz i need a clutchmy neighbor said i could borrow his tires there old mickey thompsons that r 0 tread wear so after a new clutch ill be goin back.
Old Oct 8, 2008 | 04:05 PM
SpecterGT260's Avatar
Ninja Administrator
things to check with nitrous:
tune-pulling timing is a bad thing and can almost entirely negate the effect of nitrous
tires- duh
clutch- you would be suprised how much time you can lose if this bad boy starts slipping
Old Oct 8, 2008 | 04:30 PM
z28rob18's Avatar
ORIGINAL: SpecterGT260
tires- duh
well tires hav been on the list for awhile but i need stuff b4 them and the clutch is screamin after last night its rattleing vibrating itd doin everything that y wen i get paid next week im gettin a clutch and steel flywheel
Old Oct 8, 2008 | 08:46 PM
98ss4REAL's Avatar
fix the clutch, and put the new tires on and see wat she can do! wat kinda nitrous set up do you have?
Old Oct 8, 2008 | 09:44 PM
z28rob18's Avatar
its a brand x single nozzle wet kit its a great kit for the price i got it for i bought it for 299 brand new
Feffman
South
Jun 4, 2015 05:39 AM
Feffman
Mid West
Oct 17, 2012 04:19 PM
armynatguard18
General Racing/Tech
13
Nov 9, 2009 12:25 AM
dacats67
General Racing/Tech
Jul 29, 2008 08:07 AM
