will this work?
Old Apr 29, 2009 | 08:54 PM
rockin85's Avatar
Default will this work?
i might get a 327 sbc and it has a 289 crank in it and the bore is 4" and the stroke is 3" so im sure it might be a 302 motor. i have a 350 crank and if i get this motor i wana put the 350 crank in it and it should make it a 350 ci motor right? i just wanna know if this crank can clear everything and i wont have a problem with the crank hitting the block. will this work?
Old May 6, 2009 | 12:51 PM
bobarian91's Avatar
BackseatBob
I believe the 350 crank will fit in a 327... but... WHY would you want to do that???? dude, a 302 is an awesome motor, don't buy one and then change it! Go find a 350 and build that. I swear if you buy a 302 and ruin it I'll find you and kill you.
Old May 6, 2009 | 08:24 PM
GRIFF's Avatar
Chevy made a 283 not the 289... if it does have the 283 crank in it the 350 crank will not be a direct swap because the journal sizes will be different(unless spacer bearings were used). It does make some sense that the 283 crank(small journal) is in the 327 because the 327 was made with the small and medium journal sizes the early 327 was the small and the later was the medium. Check the casting number I think that will tell you what you have. I believe the 302 also was made in the small and medium journal.
Old May 7, 2009 | 01:20 PM
rockin85's Avatar
thanks guys. but i got a 350 instead. the guy doesnt know if the blocks good, so hes gonna pay for it to get magnafluxed. if its bad hes gonna give me the 327. i guess ill run it the way it is if i get it. and one more question. i know this isnt about motors but, the t-5 tranny i have needs new sychros and i cant find a place to get them. i know chevrolet might be able to get them for me but i dont wanna a pay 1000 bucks for em. are there any sites you guys would recomend?
Old May 8, 2009 | 03:23 AM
sewerrat's Avatar
I got my parts from:
http://www.thegearbox.org/home.html. They also have an ebay store.
Old May 8, 2009 | 01:11 PM
rockin85's Avatar
sweet thanks.
383 Coupe Car
Mar 2, 2010 09:04 PM
Socom
Feb 16, 2010 12:46 AM
thatcamaro
Jan 25, 2010 04:47 PM
Z28Reggie
Aug 12, 2008 06:02 PM
92 RS in training
Jun 13, 2007 11:58 PM
