Timing Indicator
Old May 5, 2008 | 08:20 PM
CCarRocks's Avatar
Default Timing Indicator
Hey ya'll I need to find that little timing indicator that bolts up to the timing chaing cover.
Does anyone know where to find them. The local parts store couldn't get one to come up on there computer. It may help to know what to call the little guy.
Thanks,
CCar
Old May 5, 2008 | 08:34 PM
RMG32's Avatar
Default RE: Timing Indicator
They call it a timing pointer...hope that helps your search, You can find them online pretty much anywhere.
Old May 6, 2008 | 12:40 PM
88CAMERO's Avatar
a new cover may have one welded to it what year are you working on?
Old May 6, 2008 | 09:33 PM
CCarRocks's Avatar
I'm building a 383 from a pre 86 block. I went with a chrome timingcover but didn't think about the timing indicator pointer. I've seensome thatattach to the right side (when facing the balancer)of the cover using the cover bolts. But where can you find those after market or OEM. Its the one which has the degrees amrked going to 15 or so BTDCto around 10 ATDC & are basically a small curved plate.
Thanks,
CCar
Old May 7, 2008 | 07:16 PM
CCarRocks's Avatar
Okay I found one, with the correct name they pop up all over the place. All kinds of them, ugly to out standing. I got the ugly one
Thanks,
CCar
echeeba77
Apr 16, 2011 11:56 AM
Organgrinder010
Apr 1, 2011 08:00 AM
86CamaroZ28
Jun 12, 2010 05:29 PM
gxrchk07
Jan 9, 2008 05:47 PM
MartynCZV6
Oct 6, 2006 06:26 PM
