V6 "Oil change" indicator?
Old Feb 20, 2006 | 03:51 AM
MartynCZV6's Avatar
Default V6 "Oil change" indicator?
I used to buy a 2002 V6 Camaro, I´m very happy with that car But last week the Oil Change indicator starts to light sometimes. But oil was replaced before 4000Miles! I should run another 4000 without oil replacement, shouldn´t I? But that oil was changed 4K M ago, but it is more than 7 months ago (it car is runned only once a time), is possible that camaro check oil and if it is resuleted as not good it starts to light? Thanks for any answer, and sorry for my english I´m from europe..
Old Feb 20, 2006 | 10:46 AM
Linxs's Avatar
Default RE: V6 "Oil change" indicator?
You should change you oil every 3 months or every 3500-5000 miles which ever is first...
Old Feb 21, 2006 | 05:06 AM
MartynCZV6's Avatar
ORIGINAL: Linxs
Every 3 months?! I really didn´t know that, it is very suprising for me, i´ve thought i should change oil every 8000miles... Thanks for information, i´ll change that as soon as possible... And what brand / type of oil is best for 3800 series II motor? Does the computer which is looking after oil quality need to be restarted after oil replacment or is it automatic? Thanks for reply..
Old Feb 21, 2006 | 11:27 PM
6v49der's Avatar
MY GOD! I've never heard anyone keep the same oil for over 4000miles, and i personally have mine change every 2,500. But of course i have a 94 camaro so it is a little older and has some oil leakage that newer ones wouldnt.
Old Feb 22, 2006 | 10:40 PM
If you change the oil every 8000 miles you are asking to buy a new engine in a short time. For general usage change the oil and filter every 3000 miles. Long change time are for ideal driving conditions, no dust, clear level roads, no stop & go driving, mild weather, etc..
Old Mar 1, 2006 | 10:39 PM
Drew18's Avatar
My "Oil Change" light comes on after I get my oil changed. Is there something I need to do so this light doesnt appear EVERYTIME I start my car? I changed my oil last month, and when I turn my car on it comes up, and then will go off after about a minute
Old Mar 1, 2006 | 11:15 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
did you do the GM oil life reset? the process is described in the manual, but basically you put the key to the on position, step on the gas 3 times within 5 seconds. then start the car. the light should go off when you start it again
Old Mar 2, 2006 | 07:33 PM
6v49der's Avatar
Not that i'm an idiot, but where is this "oil change" light? I know there is a low oil light, but otherwise how would the car know how far you have gone on your current oil and wether or not it needs replacing? It's probably best just to do a visual check every 1000 miles, thats what i do. And i dont about your guys' cars but mine burns about one quart every 3000 so its good to check it often. Again, though, where is the "oil change" light?
Old Mar 5, 2006 | 10:28 PM
v8chvyguy's Avatar
Read your owners manual people. It will answer most of your questions.
Old Oct 6, 2006 | 04:09 PM
airchevy02's Avatar
Dude hold the milage reset button on your dash for 5 seconds before you turn your car on with the key in the on position!... it will turn it off, do this every time you change your oil....
