thermostat
Old Jul 5, 2006 | 03:39 AM
Saint_Ali's Avatar
Default thermostat
whats the best thermostat to get ? is it better to get a low degree or a high degree ?
Old Jul 5, 2006 | 10:44 AM
blackz87's Avatar
Default RE: thermostat
without changing the chip a 180 deg one would be the best for all climates.
Old Jul 5, 2006 | 02:04 PM
Agreed, a colder stat may add some power, but the fans will need to kick in just after it opens. Therefore, a low temp stat won't do much good unless you are cruising at highway speed or the PCM has been reprogrammed to start the fans at a lower temp.
Old Jul 14, 2006 | 02:39 PM
coop95z28's Avatar
If you have a Hypertech Programmer.. You can change the temp of your thermostat to 160 degrees.. Does this also tell the computer to kick on at that degree? I think it does.. Just curious.
SalsCamaro2000
Dec 14, 2011 12:38 PM
MaxTheKiing
Jun 22, 2010 11:30 AM
bluovlh8er
May 17, 2007 02:05 AM
RJayS.
82-92 V8 Tech
May 16, 2007 10:25 AM
bowtie.runner
May 7, 2007 11:32 PM
