Stroker
Old Jan 27, 2011 | 10:15 PM
junior.davilar's Avatar
Question Stroker
What all has to happen to stroke a 350 to a 383? An which kit do you recommend? T.I.A. guys.
Old Jan 28, 2011 | 12:09 PM
All sorts of things. Change crank, change pistons, plus everything else that is usually needed for a rebuild. Suggest you buy a book on modifying the Chevy small block.
Old Jan 28, 2011 | 05:22 PM
I'll look into that. Thanks Pete.
Old Jan 28, 2011 | 09:33 PM
383Stro's Avatar
Buy a rotating assembly, take the bare block to the machine shop...have them bore the block I go with between .0035-.004 piston to wall clearance for the tss gapless rings. Buy rings, bearings (mains, rods, and cam) take all of this to the machine shop with the wristpins spiro-locks (or whatever locks in the wristpin on the r-a you have. They will clearance the block for you (easier) or you can do it yourself (pm me and I will tell you how) The machine shop will have the stuff they need to then balance the rotating assembly for you. Then all that is left is assembly. That will pretty much take care of the short block. There are several clearances to know and check along the way.
Old Jan 28, 2011 | 10:35 PM
Thanks 383Stro. Do you recommend anything as far as parts? An if you can let me know the clearances I would appreciate it. I'm a newbie with doing internals with engines so anything would help. Thanks again.
italiafutbol07
Jan 6, 2011 06:31 PM
Sodamhot
Oct 3, 2009 10:05 AM
morphine51
70-81 V8 Tech
Feb 25, 2009 09:26 AM
buckfever
Dec 15, 2007 10:25 PM
travis t
Oct 29, 2007 07:48 AM
