Specter Blowout Power Valve Protection
Old Nov 10, 2008 | 05:02 PM
kyphur's Avatar
Default Specter Blowout Power Valve Protection
So I installed the blowout power valve saver from Specter in my 750 Holley and now when I gas the engine it sounds like a whistle. Anyone else have this problem?
Old Nov 12, 2008 | 05:44 PM
kyphur's Avatar
Default RE: Specter Blowout Power Valve Protection
I figured out what it was. It was the carb gasket between the spacer and the carb. Apparently it was just a piece of poop. I thought it might've been the baseplate to main body gasket and when I pulled the carb to replace it I noticed there was some moisture near the rear of the gasket to the plenum holes. Put a better gasket on and now it's as good as new.
southerncarparts
Jan 8, 2011 06:12 PM
SpecterGT260
VS
14
Apr 19, 2008 10:43 AM
dencor01
Jan 25, 2008 10:08 AM
SickSickSick
May 1, 2006 10:59 PM
