Spark plug help
It depends on the compression ratio.The higher compression is, the colder the plug needs to be. So going by that, look at the recommended plug for an engine using those heads in stock form and usung Your compression, judge accordingly. Gap is usually safe in the .045" range.
QUICKB4C
Jun 15, 2009 11:52 AM
